Old 05-26-2016, 11:00 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: Difference Between 2 Raw Motor Kits
Latest PK80 40mm stroke engines are best right now.....
BeKits sells them. as well as some others, but BE SURE it's a true PK80 engine. Tags are cheap. The 40mm stroker crank and much better castings & jug are the real upgrades!
