Old 04-12-2016, 11:21 AM
Mr Turdle's Avatar
Mr Turdle Mr Turdle is offline
Default Re: Starting 2 stroke with electric drill
Originally Posted by crassius View Post
I have twice seen someone strip that nut starting with a drill - you might consider a compression release to use with that.
Thank you for the advice sir, as that is something I had not considered. Can you use the compression release to make starting while pedaling easier? If so, this may be a better idea. I assume I would have to change the head to install a release valve?
