Old 03-04-2016, 03:06 PM
Tony01's Avatar
Tony01 Tony01 is offline
Default Re: Budget BTR Build
What was the question again? A btr frame is available for a price that will save you a lot of headache and will definitely be safer than the first frame you build.
Bottom line is that a bike with heavy duty enough components for a gc160 or similar is going to cost you at least 1200 in parts alone not including custom frame building but including a stock frame from a reputable manufacturer. I'm taking brakes, wheel builds, engine and transmission. Building and /or modifying a frame is a huge PITA. I say get the sportsman frame and build on that.
Expect to spend at least $300 on wheels. The best deal for a rear sprocket and brake is the treat land moped hub for $55, build a wheel on that. For your front you'll need a quality hydraulic brake if you want to stop safely from 45mph. $50 plus the wheel and a fork that's heavy duty enough if you decide to go with suspension will be another 2-300.
I don't always listen to Alice in Chains..... but when I do, SO DO THE NEIGHBORS
212cc 2-speed
