Old 01-30-2016, 07:19 PM
cannonball2's Avatar
cannonball2 cannonball2 is offline
Default Re: Here I go again,Briggs build
Originally Posted by scratchbuilder View Post
Hey.....since your here. I've search for 3 speed sa jackshaft and no go. Can you help with the how 2's. Like how to put a sprocket on the opposite side...or just how is it done.
A 4stroke will be pretty hard on the internals. I used the SA fixie hub its really stout. Stands up to pedal starting a CG with no issues. Also since it doesn't freewheel you have engine braking which I like and it will turn backwards just fine unlike standard 3speed hubs.
I modded a sprocket to fit the spoke flange which could be done on either side. On this build I wanted the drive all on the left. It has worked out well. This bike rides and sounds like a small motorcycle.
Nice build BTW.
