Old 10-26-2015, 10:23 AM
YesImLDS's Avatar
YesImLDS YesImLDS is offline
Default Re: HELP with SPROCKET bolts and brake arm at hub
Easiest thing to do would go somewhere you can get it bent slightly. Sounds like you are trying to over complicate the solution. You could try your other solution but it's not guaranteed to work so you may be spending unnecessary money. Are you sure there is no way you can bend it? Get creative you don't need a vise! Try some vice grips!
