Old 07-29-2015, 10:57 PM
Springfieldscooter's Avatar
Springfieldscooter Springfieldscooter is offline
Default Re: Cylinder Stud broken
How much threads remain on the top of the broken stud?
If you have enough threads, you can install 2 nuts on the broken stud. Then tighten the 2 nuts against each other as tight as possible. Then use a wrench on the lower nut only to remove the stud!
