Old 07-29-2015, 05:01 AM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: very bad gas mileage.
Moving the clip up lowers the needle to lean the mixture, while you are working on the carb check the jet to make sure its tight. I've had the main jet get loose on two different type carbs.
Your results may not be the same,Greg
