Old 06-18-2015, 07:08 AM
2door's Avatar
2door 2door is offline
Default Re: Best oil filter to run on a China Girl? Is the Serve Pro ok?
If you're going to use oversized valves then you should also look at adding a cam with higher lift and longer duration. It makes the idle a little lumpy but you'll love what it does at the higher end. Are you using solid or hydraulic lifters? Roller rockers?
