Old 06-08-2015, 10:25 PM
egjsc's Avatar
egjsc egjsc is offline
Post New Rider In Oxnard,CA Area
Hey all, just want to see if anyones located near the Oxnard,CA area. Had my bike for a few weeks now and gettn it dialed in. Its a blue/black Huffy Cranbrook beach cruiser and Sofar upgrades include main jet kit(running #73), Thunder CDI ignition with ngk #8 heat range plug(Ngk #7 on the way), Banana Pipe, Spring Chain Tensioner, Upgraded Dual U-Bolt Front Engine Mount, High Grade Engine Bolt Kit, Cone Air filter W/ Velocity Stack, Carb O-ring, and upgraded bottom end kit from W/Balanced Crankshaft is on order. Looking forward to getting the balanced crank in there, I can tell the engines got much more potential if it wasnt for that dreaded " vibration point" that hits in at higher rpm. Sofar Ive busted a rear engine mount stud(broke flush w/case which was fun trying to remove), also the soder that held a wire to the magneto vibrated loose while riding. I think thats it for now, tryn to work out all the bugs and replace the problem parts with better/upgraded ones. I have around 2 gallons of gas through it sofar. Ill post some pixs soon so you guys can check it out. Happy riding! With Regards, -Erick-
