Old 02-14-2009, 01:04 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Throttle useless
you want to custom make or modify the throttle cable or a cable end I cover this in the classic posts on how to make a cable end and for the throttle I even have pictures of how to do it.
It involves make the end that goes into the throttle slide out of phone wire and using silver solder to make it permanent all you need is a propane torch and silver solder/flux. Regular solder should not be used as it isn't strong enough.
I also have a way to make almost any end needed for cable ends and I can make them to lengths that you can't buy over the counter.
