Old 05-19-2015, 07:22 PM
2door's Avatar
2door 2door is offline
Default Re: Hello From Wisconsin
Glad you're back in the saddle.
Mag coil failures aren't uncommon and can usually be traced to cold/bad solder joints on the core. If you take a close look you might see the problem and can fix it and keep the coil as a spare. They are prone to failure if subjected to moisture. Always seal the wire exit port at the front of the case and make sure the side cover gasket is good and in place.
Have fun and ride safe.
