Thread: yeah!!!!
Old 04-05-2015, 05:19 PM
KCvale KCvale is offline
Default Re: yeah!!!!
You need a need a new carp set screw but if your idle is too high even without one it is most likely your throttle cable.
There is an adjustment at each end.
The object is to get the outer sheath just the right length so the inner cable itself can go far enough to let the barrel go completely down to the idle set screw stop, but not be so loose it can come off it's stops and not let you get full throttle.
You need a replacement screw though as you will never be able to set idle with cable alone, it changes every time you turn your handlebars.
KC's Krusiers Builds
