Old 03-19-2015, 09:15 PM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
Default Re: what did you do to your motorized bicycle today?
Fired up my Bridgestone/Mitsubishi chain drive 35cc , and it just..SSSCREEEEAMED!!! This may, it will be 7 years running. last two days, I rectified my spark lead, solderd on a new ground, and added a third spring to my clutch, did some gas tank work too. My magneto braket, broke right off the engine but as long as the mag stays tight up against the motor, it wont go anywhere, so i used hanger strp. I also added some high heat shim gasket papper between the mag and motor head. here are pics. The papper stikin out is my mag clearance gauge. ( two cig pak card board stuck together. ) My clutch springs work really well, and have not smashed up yet.
Last edited by Blakenstein; 03-19-2015 at 09:39 PM. Reason: add the word screamed.
