Old 02-17-2015, 10:21 PM
MotoMagz's Avatar
MotoMagz MotoMagz is offline
Default Re: Update on my first build.
You can remove the link yourself. Get a small socket or a nut. Set the Chain on which ever one you are useing. With pin in the center take a punch or nail set and hit the pin out almost all the way. Leave it in the bottom plate. Remove desired links and and re assemble Chai with pin now facing up. Hit it in with a hammer..don't go crazy or you will bind the chain. Get it so it is flush with the bottom plate use punch ..NJT this time just tap it enough to stick out of the plate like the others.
