mapbike
38-40+ MPH is easy with the right engine set up like starting with a Dax "GenIV" lower, these engines are so much better balance than many of the others and with some good clean ports and a good tuned carb and good flowing exhaust, they will do 40MPH no problem if the gearing is right, I weigh 215LB currently and with a 34 or 36T sprocket I've seen 45+ MPH on two of my bikes running the Dax GenIV lower built up nice.
Map
			Map
