Old 01-21-2015, 01:12 PM
YesImLDS's Avatar
YesImLDS YesImLDS is offline
Default Re: Cracked Skyhawk GT2 Frame
Originally Posted by Davezilla View Post
First one I've seen to crack, but looking at how clean it cracked around the weld, it looks like the weld was cold and didn't penetrate into the frame metal, but just the post the bracket is on. If this is the case, that'll cause the crack and for it to spread up the frame tube like that when it's subject to vibration and road bumps etc...
I'm pretty sure if you can have it re weleded it'll hold better than it held new.
Exactly. I'd just go look for someone who does head reworking because that has to be a good quality weld for it to be machined perfectly. A good weld as well as some good prep and you'll be back on the road in no time. Who knows he might even look over the other welds and strengthen those too!
