Old 01-20-2015, 07:50 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: The Iron Horse is back again.
Slowly coming back to life...
I figure I will make a plate to cover the mag area to keep it a little bit cleaner. I'll bolt it on between the cover and the case and maybe use some silicone to seal it against water and grease.
