Old 01-13-2015, 08:22 PM
Davezilla's Avatar
Default Re: what did you do to your motorized bicycle today?
Thanks, I was thinking about putting the swing arm on another bike that has a steel frame so I can weld the linkage brackets in and relocate the rear shock so it can be used but out of the way similar to Theon's last summer project, that would also allow me to convert this one to a hardtail, then the engine could bolt to the seat post and I'd need to make some brackets out of some billet bar stock since the bottom tube is an odd shape.
I'm still debating on just stripping all the parts off this one that I can use and saving the frame for something else too. I'm happy with the silver bike but putting that front disc brake on it is something that one can use, the V brakes just don't cut it when ya need to stop quickly from a high speed run. I've only been getting away with it now because the street I ride it on has no side streets and I got anough room to coast down to 20 or less before using the brakes.
