Old 12-22-2014, 08:07 AM
Davezilla's Avatar
Default Re: what did you do to your motorized bicycle today?
Excellent link Indeed... Bookmarked here too.
My front end uses a modified go kart shock, modified in the sense that I had to drill the bottom eye hole out to 5/8" and the top hole to 1/2", then use a MTB spring to get the right spring rate. Looking at the availability on that site they might just have one with the right spring rate and length pre made, but I do see some that would work if I make a swing arm and dual shock setup for the rear... Now you got me thinking again
