Old 12-21-2014, 09:33 PM
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
I saw this tip else where on Youtube, but I did not go looking for hardware to make what equates to an extra hand to hold down the top of the valve while attaching the cup or pin to the valve stem.
Used one of the head bolts and extra shroud part of metal with the exact size hole for the head bolt. I needed a shim and use a socket that worked. Then with the valve spring compressor and a needle nose pliers had it an easy task putting the valves back in after adjusting and lapping.
