Thread: Engine enamel
Old 12-20-2014, 01:00 PM
2door's Avatar
2door 2door is offline
Default Re: Engine enamel
This subject comes up often and there isn't a good answer. There are a lot of opinions however. Some will say you must use high temperature paint and others have used cheap rattle can stuff, all with good results.
Personally I've used both and have had good luck. I like to color match the engine with the bike and have used Dupli-Color automotive spray paint and never had a probelm.
Some paints are not compatible with gasoline so you need to keep that in mind. If you want a good fuel proof clear coat over the color I've been using Top-Flite model airplane clear over paints that won't take gasoline. It's available at hobby shops.
Whatever paint you choose you need to make sure the engine is clean and oil free or no paint will stick. Use a good solvent to clean the engine before applying any paint.
Just be patient. You'll get other opinions and suggestions on painting the engine.
Good luck and show us your results.
