Old 11-29-2014, 08:35 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Default Re: Confessions of a first time MB builder
Originally Posted by BobbyT View Post
Soldering the connections is a good idea. I recommend using some good heat shrink on them. Get the good stuff from a electrical supply store that has built in sealer. Don't forget to put the heat shrink on the wires before soldering.
They beat me to it. This is what I did on mine. I slid on some heat shrink tubing over one wire, stripped the ends I needed to connect, twist 'em together, solder 'em up, slide the tube over 'em and shrink 'er down. You'll have grandkids before you'll need to worry about that connection.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
