Thread: Mill/Lathe
Old 11-23-2014, 12:51 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: Mill/Lathe
Dan if you get everything just right the metal will be coming off in one continuous piece like wire, I was making replacement shafts for 72" exhaust fans in the spring, after spending a little time back on the lathe setup became easier with better results.when you get the setup right you will hear very little noise from the cutting action.
Your results may not be the same,Greg
