Old 11-20-2014, 03:55 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: Pretty little 49cc engine!
Originally Posted by maniac57 View Post
Thanks for the confirm Greg! Every part I've seen looks great so I expect nothing different inside the case...
This one is going under the grinder before I place it back in service! Those huge ports are just BEGGING for a performance build....
Well I got some bad news...
The mains are NOT the same size as the 66cc. They are bigger! (And seriously wasted!)
The third picture shows a standard 66cc main bearing in the 49cc case. Quite different unfortunately.
Now I'm dead in the water since I cannot afford to buy bearings at this time.
