Thread: A little help
Old 11-04-2014, 07:41 AM
Motor awesomeness Motor awesomeness is offline
Default Re: A little help
True the gas tank has to be higher than the motor, but I want to use the original tank cause I want this project to be as cheap as possible. Plus the chain shouldn't come off if i keep it tight. I think in the first post I said no welding because it's not that i don't have have welder, I have a welder, but I live in a apartment complex and their isn't a outlet on the outside of the building so the only way I could weld is to take out the generator which is very heavy. When I'm done, I have to walk down a flight of stairs to the storage lockers with the welder and the generator which is heavy and requires 2 people and I don't have another person to work with me. That's why I said no welding.
