Old 09-22-2014, 05:05 AM
Greg58's Avatar
Greg58 Greg58 is online now
Default Re: Hey new and tech help needed
Welcome to the forum, you are correct on removing the clutch plate. Its easier to remove if you take out the small screw then lock in the lever and screw off the flower but. Keep track of the turns it takes to get the flower but off for a reference point when you put it back on. There are small ball bearings in the big gear that may be your source of movement, be careful if you take it apart.
Your results may not be the same,Greg
