Old 09-21-2014, 12:30 PM
Slogger Slogger is offline
Default Re: New owner need help
All that oil must have slimed your carburetor jet. Pop the carb off ( and remove the float bowl) and clean it with carb spray, change the fuel filter if you have one, and it should start. You might want to check the spark plug to make sure it's not oily, too.
All this may not be necessary but the fix is here somewhere.
