Old 09-19-2014, 01:13 PM
KCvale KCvale is offline
Default Re: Reducing Vibrations at High Speeds.
If your engine is in tight and it's just a little normal vibration just change your grips.
I cut that hard plastic crap grip off the throttle and throw both away and use foam BMX grips on every build, the difference is amazing.
The BXX foam grips will stretch a bit with some warm soapy water and you can 'milk' them onto the throttle barrel pretty easy.
It's your hands on the handlebars, why grip hard plastic?
KC's Krusiers Builds
