Old 01-23-2009, 02:07 PM
georgeknight's Avatar
georgeknight georgeknight is offline
Default Vibration and Noise contol
I came up with a simple vibration and noise contol for my bike engine. I had a piece of 1/8 inch rubber belt that was used on a conveyor. I cut it to fit in between the mounts of the front and rear on my bike. I also took my clutch cover off and made a template of the inside. Then cut a piece of the rubber belt to fit inside. I had to cut a circle in the center to clear the clutch assy. Used contact cement to glue it in. After I let it dry over night I gave it a good test drive of about 135 miles. I don't have the clutch noise or the vibrating handle bars. I also don't have the bolts loosing up on my bike anymore. Hope this helps someone with their project...............George
