Old 09-11-2014, 08:21 AM
Henshooter's Avatar
Henshooter Henshooter is offline
Default Re: 4 stroking at low speed
The standard jets on the factory carbys are way to big IMHO usually .68 ,my suggestion is to go down to a .65 and see if that helps
But we really need more info such as jet size the oil your running and the type of carby ( I suspect the NT )
There can be only two main suspects in my oppinion and they are jet size and fuel mix .
Being a newbie you can get somewhat daunted by the carby adjust but it's simple ,I always run in my motors at 25:1 and general running after breakin at 32:1 ,you should find if you are running the kit recommended mix ,swapping down to 25:1 should somewhat fix your four stroking issue ,40:1 for breakin is IMHO way way to low to be any good for the motor
Try these and get back to us with your results
Regards Hen
Light travels faster than sound ,ergo some may appear smart until you hear them speak
