Old 08-11-2014, 06:26 AM
Theon Theon is offline
Default Re: How to tune an engine with a temp gauge?
Agree, you don't want it 4 strokeing while your at cruising speeds,
A little bit low down is OK, and you may find it will pull a little better if a little rich down low.
But shouldn't be 4 stroking while your accelerating, that is defiantly too rich.
But I think it should 4 stroke a bit when off the gas, and maybe a little while riding slowly with gentle throttle inputs. Then when you give it a squirt it should 'run clean'.
