Old 07-14-2014, 07:55 PM
2door's Avatar
2door 2door is offline
Default Re: Need a lil help here
You really need to get rid of the small spring between the clutch actuator arm and the end of the cable. It serves no useful purpose and only makes the clutch harder to pull. The larger diameter spring that came in the kit is actually used as a heat shield to protect the clutch cable housing from cylinder heat. Retain it but discard the small one.
