Old 07-13-2014, 09:18 AM
hcrft hcrft is offline
Default Re: centrifugal clutch question
thanks so much for your response. I thought I had you figured the answer out and I'm glad I was wrong. I would really like to be able to use these centrifugal clutch kits without a pull start. I will check it out boy goes fast as I've seen some of the stuff online before. Can you recommend anyone else that sells the centrifugal clutch kit with the one way bearing?
