Old 07-06-2014, 07:50 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: New from Merrimack Valley, Mass
You have already learned one thing, use loctite on anything like mounting bolts, pedals and so forth. Vibration from the engine can and will loosen things up. In picture #8 it looks like the sprockets are not aligned, look from the back at the chain it should go off the rear sprocket in a straight line to the engine sprocket.
Your results may not be the same,Greg
