Old 06-30-2014, 02:07 AM
Theon Theon is offline
Default Re: Dual Suspension 'Roo'
After realizing that my new centerlock wheels are 32h a rag joint wasn't an option, so I decided to mount the sprocket to the disc mount.
I drilled out the studs that hold the disc to its mount, drilled out disc and mount to 6mm, and drilled the sprocket also to 6mm to match the spacing.
I thought about making a spacer ring, but ended up just using 6mm nuts to space the sprocket and disc.
