Old 01-17-2009, 03:27 PM
Dan's Avatar
Dan Dan is offline
Default Re: new to the site, need lots of help
IF it starts but dies soon sounds like you need to adjust the fuel flow. Easiest way is pull the throttle cable up on the carb and tighten down the screw so it is getting more gas. If it just won't light off, Try it with the kill switch disconnected first. If that is the problem might just have the wires wrong.
In chat you said it would start but dies fast, so I may not be following you correctly.
No worries, you will be up and motorized bicycle riding soon!
worst apocalypse ever
