Thread: i need help
Old 06-26-2014, 01:24 PM
j.rock j.rock is offline
Default i need help
How com when the engine would run i try closing my cluch and it would grined I was just tring to put in neutral so it could idle. Anyways still riding i drove for all most a couple of hours and my mix was to break it a two leter of gas mixd with the ratio 4oz of 2 cycle oil semi-synthetic smokeless low ash hi performance oil by Lucas brand this happen on my scound mix with gas nothing is clogged I have a little gash in my cluch wing arm in side ware the chain goes and a small grove inside ware the ware the wing arm drops down in to also my chain grined down the edge on the inside of my cover I use regular gas to mix with my ratio I adjusted the little clip on my pin on each setting when I let my clutch open it seem like it wonts to go dont keep running I adjusted my gear plat with the flower nut im made shore that the bike could move Back in fourth wile cluch is closed and button is pushed down. ground my Pads arnt grained down alaway pads are Orange they look got kid of dirty black.
