Old 06-23-2014, 01:10 PM
Davezilla's Avatar
Default Re: broken threaded rods
Yup... Just ask any auto parts place that sells tools for an easy out set and they'll know just what you need, basically, you need to drill a small hole thru the stud or bolt that's left inside the block then you tap the easy out in with a small hammer then you should be able to just unscrew it out with the easy out.
