Old 06-16-2014, 09:08 AM
Davezilla's Avatar
Default Re: Advice for them as likes to replace bucking bars
Definitely good advise, I was going to recommend drill rod stock because it's a harder steel and it already has an accurate and smooth finish.
Automatic transmission fluid is an excellent oil and it's also an excellent cleaner when you got grease and road grime covered parts, just scrape off most the caked on stuff and soak overnight, the parts will be clean as new after teh ATF is washed off, longer soaking may be required if the parts are really badly caked with old greases etc, but it will clean it... Good for cleaning bearings and the internal clutch parts.
