Old 06-13-2014, 04:42 PM
wheelbender6's Avatar
Default Re: Problem with centrifugal clutch - Newb
I used a combo of extra gaskets and grinding the inside of the clutch cover with a dremel.
I did not grind down the pins on the manual clutch because I wanted to keep it functional for pedal starting.
“You're only young once, but you can be immature as long as you like" -Unknown
