Old 06-12-2014, 11:42 AM
ishman ishman is online now
Default Re: Hey Dudes! Another first timer from Detroit!
OK here the Pics, first is the clutch bell showing the wire that holds in the one way bearing. Second pic shows how the clutch pins are contacting the cover and the third shows how much the pins interfere with the the cover holding it up. The last picture shows one of the holes in the extension shaft. There 3 all together, that is why I was thinking of putting some grease in the hollow extension shaft so centrifugal force would push the grease out the holes and keep the shaft lubed, instead the whole mess of drilling holes from the outside of the case through the gear and using WD-40 as lube.
