Old 06-03-2014, 11:19 AM
2door's Avatar
2door 2door is offline
Default Re: how to use the choke
What engine do you have? We are assuming it is a Chinese 2 stroke because they are the most common.
What carburetor do you have? If an NT or NT Speed, the lever down is 'choke off or open'. Lever up is 'choke on, or closed.
After the engine starts and runs for a few moments the choke lever should be in the down position, choke off, from then on. If you have to run with the choke on or partially on, you have an air (vacuum) leak.
