Old 05-30-2014, 02:42 AM
mr42ndstblvd mr42ndstblvd is offline
Default Re: Breaking in a new motor
I like to run about 7 ounces of oil during break in. I also. Add in a cap full of royal purple automotive engine oil it has zinc And other minerals in it that aid in the break in process basically build it. Fire it idle it for about 2 mins when it first fires then ride it around for the first tank at low rpm quarter throttle don't rev it hard or go full throttle after your second tank do short bursts of high rpm then let it idle back down then coast for awhile and do it again till you have ran that tank thru after the first 2 tanks I like to change the plug even on tank 3 I like to run a little over 6 ounces of oil just to make sure its broken in properly the most important thing is to ride and let the engine cool down till its cold before you ride again
