Thread: Jag cdi
Old 05-26-2014, 02:54 AM
Techbiker Techbiker is offline
Default Re: Jag cdi
Originally Posted by mapbike View Post
Ok ill shut up with my semi hackjack post here.... and ill create a new thread with my test results when I get that little job done.
Map, good luck with the test! I am awaiting it rather anxiously because I believe many forum members are being cheated out of their money for ineffective CDIs.
Toothy, if ignition timing is too aggressive and you are experiencing some detonation, you could also run a higher octane gas as a test. If the stock CDI does not cause any detonation and doesn't create pitting in the piston, I doubt that ignition timing is a problem. As map said, moving to the stock CDI might net you more power without any consequences.
