Old 05-21-2014, 02:57 PM
Tyler6357's Avatar
Tyler6357 Tyler6357 is offline
Default Re: A plethora of problems
If you hold the clutch handle in and the engine sprocket won't turn freely than the clutch plate is probably too tight. Take off the cover and hold in the clutch handle, then loosen the set screw and then turn the clutch plate screw until it will properly disengage, then retighten the set screw, put the cover back on and you should be good to go. Also, if the chain is getting jammed it is probably too loose, use the chain tensioner to tighten.
