Old 05-18-2014, 12:11 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Soft springs on new seat
You might be able to take a short length of 1/4 -5/16" or 3/8" black automotive fuel line and split it so that it will slip over and around the springs, then maybe two or three thin black zip ties could be used to secure it at each end and maybe one in the middle, if done right it wouldn't look bad and that would for sure add extra support.
Lay the line down flat and with a sharp utility knife just cut a slit down the legth of the hose and then install it over the spring.
just the first thing that came to mind, might be worth a try if the tubing you're using now doesn't hold up well.
