Thread: engine help?
Old 05-15-2014, 06:46 AM
allen standley's Avatar
allen standley allen standley is offline
Default Re: engine help?
Yeah sounds like a serious compression loss. Check Head Nuts first- if loose pull the head and check the gasket
" i hear noise that sounds like Air coming out from the clutch plate side."
Do as Gearnut says, pull clutch cover and check for oil/gas Leaking. If wet at all in there you blew out a case seal.
