Old 05-12-2014, 08:16 PM
crassius crassius is offline
Default Re: thick or thin base gasket?
changing the gasket will change your port timing, which may be good or bad depending on whether you liked it as it was
the thin gasket *could* let the piston smack the head
the thin gasket will give a smaller combustion chamber, which may mean higher compression if the new port timing will completely load it
Sometimes I sets and thinks, sometimes I jes sets.
