Old 05-08-2014, 07:41 PM
Henshooter's Avatar
Henshooter Henshooter is offline
Default Re: Yet another mixture thread, or...? (Starting problems)
Originally Posted by 2door View Post
Clean or replace your spark plug, check the muffler to make sure it isn't clogged and inspect the exhaust port on the cylinder. Mix a new batch of fuel and mix it at 32:1, drain what is in your tank now and dump in your new mix.
Get back to us with the results.
Oh, and tell your friend to log on here and do some reading from builders with a lot of experience, years in fact, with these little Chinese engines. He might change his mind.
Well said Tom and I have to completely agree , I used to have the exact issues described by teratoma and was using a 16:1 mix ,some friendly advice by you guys has me change up to a 32:1 mix , my motor never misses a beat , takes 10-15 seconds to warm up and as such reaches wot after this short time perfectly, never again will I use the recommended syrup mix and will stick with 32:1
No excess drips from the exhaust and the motor doesn't have that somewhat unpleasant 2 stroke smell
Light travels faster than sound ,ergo some may appear smart until you hear them speak
