mapbike
Got my number-drill set in the mail. Got some rejetting to do as soon as I get a chance.
Excellent.... a well tuned carb makes a huge difference in how these little engines run.
Map
Then you know it's time for a 'safety wipe' just in case ;-}Your neighbors to the north refer to that as a 'shart'.![]()
I'm waiting on a set of bits for carb jetting myself. Figured it was finally time to get all my junk running as good as possible.
The main thing motivating me is too much four stroking around my normal cruise rpm.
Just sounds so crappy when it's blatting and missing at trailing throttle.
I know I can clean it up quite a bit with some time invested...just been too lazy till now, but with the FredHead and the GenV coming back online it's time to step up my game!
Dude!
2. Remove tank from bike. Drain all fuel. Let it sit open overnight in an outdoor location(but covered so rain won't get in it) to vent fuel vapors.
6. This is THE MOST IMPORTANT PART: Bake the tank in an oven at 200° for one hour. This is why you MUST make sure there is NO gas fumes remaining in the tank, or your oven may catch fire or even explode..
Yes, completely normal.Is it normal the fact I get a big grin on my face imagining the oven door exploding open by some numbskull that may not have gotten all the gas out of their tank ?
I never thought about using dry ice before but that would work great for displacing gas fumes. VHT is enamel paint that is resistant to chemicals, including gas, but it has to be properly cured (i.e. baked) for those properties to manifest.Seriously though...if you have access to dry ice some gas.companies will use dry ice to evacuate vapors from under ground gas tanks. I guess by law they have to use it. It works pretty good too. When ever Im about to paint my tank I drained the gas remove valve, then filled it with very hot water and Dawn soap det,I shake the bejesus out of it drain & repeat till I smell nothing I never tossed one in the oven though
Kyle Petty & Ted Nugent, huh? Never heard that one before. But thank you, I consider both individuals to be swell folks & I'm honored by the comparison!You know Dave I was thinking after watching your video (http://youtu.be/uxHMqGT2Zak) man he looks like a cross between Kyle petty and Ted Nugent So I clicked on Kyle Petty then remembered his son Adam Petty and I also remembered the fact he died at the Loudon NH speedway so I looked him up to see a picture of him & was shocked to see he passed away 14 years ago to the day May 12th 2000 talk about weird huh! . So here's to you Adam Petty The first 4th generation NASCAR driver ever. R.I.P. son!!
Great pic.That is good workNice. ......... I like that tank, I need bigger tanks on all my bikes...
